Images under entities are moving around while zooming
This can only happen in perspective views where the entities are not in the same plane ...
0 -
If this is not the case, can you please file a support request and add the drawing you are having this issue with. Our analysts will be glad to investigate.
0 -
Rendering if its set on 2D Wireframe then is ok
0
