Briscad closes when opening a file from within Bricscad
There is a setting how to handle multiple documents.
SingletonMode ( ?) or SDI (=Single-document Interface)
I think the default is to use 2 instances of Bricscad,
which does not work on macOS.
It tries to open a second App instance but macOS prevents that.
So I can open an additional document only from within Bricscad's
open file dialog.
Maybe checking these may also help (?)0 -
When my first file is opened from within windows explorer, and i want to open a second file with Bricscad, Open, Briscad closes all files without asking to save first.
The SDI registry setting is the same as on a machine where this problem doesn't occur.
0 -
Do you mean it closes normally or just like for certain files for me,
when it just crashes when trying to open
Often it works on a second attempt without recover or audit or such things.
But that can happen for me too when opening by Bricscad welcome dialog.0 -
I had this problem not long ago. For me it helped, to take a user profile from another user that hadn't this problem and rebuild mine from that again.
I compared the profile-files but didn't see anything special - maybe just the combination of setting s?
So try another profile and see if it's gone.
Mathias0 -
Creating a new user profile solved our problem. Thanks!
0 -
Oh, I already forgot about corrupt user profiles.
That happens easily for me too.0
