autoload and autostart of VBA macros
is there an solution for autoloading an DVB on Briscad-startup and autorun a makro?
The AutoCAD solution is an acad.rx file and a dvb file named acad.dvb with a procedure AcadStartup() in the Thisdrawing area.
Thanks a lot
  • New BC user and I have the same question.
    Thanks a lot
