Field / Variable for Standard Skalierung ( scale )
Hello, again me...
if i want to plot a Layout in a specific scale i use the standatd scale field in the properties of the layout window. Great...
But i want to plot the value of scaling for example 1:10 automatically. For those things i use fields. But there is no one for this scale. There is a variable for plotscale, but this is not that what i want.
Can anyone give me a hint about that ? I Know that it can be a problem if you use more than one Windows with different scales but if i Want to use only one, it should work.
Marc
  • Objects > Object > Pick Viewport > Select 'Custom scale'.
    Using 'Custom scale' is better. If the VP has a non-standard scale a field with the 'Standard scale' displays 'Custom'.
  • Thank you !
    ...but very difficult to find...
    Marc
