BIMsection export with rooms
Hello,
Is it possible to make BIMsection-plan export with BIMrooms including names, numbers and areas of the rooms?
  • Roomlabels can be added to the plan section using the BimTag command: when in the layout, launch the command, then click the viewport border.
  • Louis, Thank You.
    It doesnt work.
    V18, Ubuntu 16.04
    ._bimtag
    Select BIM section result [Manual]:
    Model section object cannot be found.
    Invalid selection.
  • Select BIM section result [Manual]:
    Did you select the viewport border in a paperspace layout?
  • Yes, thousand times
  • HI Martin
    Can you file a support request and add your model?
  • SR # 81452
    Thank you Louis
