BIMsection export with rooms
Hello,
Is it possible to make BIMsection-plan export with BIMrooms including names, numbers and areas of the rooms?
0
Roomlabels can be added to the plan section using the BimTag command: when in the layout, launch the command, then click the viewport border.
0 -
- Louis, Thank You.
- It doesnt work.
- V18, Ubuntu 16.04
._bimtag
Select BIM section result [Manual]:
Model section object cannot be found.
Invalid selection.
0 -
Did you select the viewport border in a paperspace layout?0 -
Yes, thousand times
0 -
HI Martin
Can you file a support request and add your model?0 -
SR # 81452
Thank you Louis0
