Wouldn't it be good if Shape could ...
Have MTFLAGS set to =7 by default ?
0 -
Sort Layers by Name,
or at least let me sort them manually by dragging ?0 -
have some graphical user interface or onscreen drawing guidance
to setup Arrays ?0 -
@Michael Mayer said:
.... insert PDF Underlays ?
(To sketch over Sketches)I revert my opinion.
Beside PDF snapping which I avoid because of PDF accurateness anyway,
it works really well (if not better) if you convert the PDF before and insert it
as a standard raster image.
Even at ridiculous high resolutions.0
