Wouldn't it be good if Shape could ...
Michael Mayer
edited April 2018 in Shape
.... insert PDF Underlays ?
(To sketch over Sketches)
  • Have MTFLAGS set to =7 by default ?
  • Sort Layers by Name,
    or at least let me sort them manually by dragging ?
  • have some graphical user interface or onscreen drawing guidance
    to setup Arrays ?
    I revert my opinion.
    Beside PDF snapping which I avoid because of PDF accurateness anyway,
    it works really well (if not better) if you convert the PDF before and insert it
    as a standard raster image.
    Even at ridiculous high resolutions.
