Boundary is always calculated and displayed?
I have a 3rd-party-defined profile, and this results that
  • only moving the mouse to a position inside the drawing
  • it searches the "boundary"
  • draws it in "preview mode" and
  • displays area and length of the boundary beside the mouse
Where can I disable this feature?
Using another profile does not show this behaviour...
  • This feature is called 'Rollover Tips' to get rid of it click the RT field in the Status bar at the bottom edge of the BricsCAD window.
  • Thanks Louis
    the box with the calculated values is now gone. But the "preview of the boundary-line" is still here.
  • Try setting "SELECTIONMODES" to 0
