How to insert field values into attributes
Yes we can reproduce on Linux. It was already reported in a support request and meanwhile it is fixed internally.
The fix is included in the upcoming BricsCAD(Linux) V18.2.16 BETA.0 -
Thank you, that sounds great.
0 -
For what it's worth, even without the fix it is possible to insert a field in the value of an inserted attribute. After having inserted a block containing an attribute definition, double click on the attribute, then right click on the value to insert a field.
But I did not find a practical workaround to add a field in the default value of the attribute (the default value is the value of the corresponding attribute definition).
0
