Failed to load LicenseManager
Hello
I've been happily using Bricscad v.17 all year, and used it last night.
Now, today, it will not start, popping up error message about "Failed to load LicenseManager" and then aborting.
I have tried running as administrator, reinstalling, but always get the same error.
Same applied when trying to load Bricscad Shape.
I can load and run autocat LT on the same machine no problem though.
Doe anyone have any ideas on how to fix this?
Many thanks in advance
E.
  • eburt
    edited July 2018
    OK - so it would appear for some reason McAfee is quarantining rlm1222.dll from bricsys program folder, which is causing the problems.
    Now battling to get mcaffee to remember to leave it alone, but I have managed to get bricscad started up in the meantime.
    Edit: typo
