Rotating a graduated fill
I have drawn some cylinders and hatched them with a graduated fill. However when I rotate the cyclinders 15° the fill remains unchanged. I have tried altering the angle in the Hatch box and also in the Properties box but neither approach works. Is this a known problem? And if so has anyone discovered a work-round? Thanks.
Found the answer seconds after posting this! Which is to cut and paste as a block. The integrity of the graduated fill is then retained and it rotates exactly as required.
Howdy, Stranger!
