Circle by means of tan-tan-tan
Am I overlooking something of does Bricscad not have the possibility of drawing a circle by means of 3 tangents ?
0
Ai_CircTan
Draws a circle tangent to three entities.
Accessing the Command- command bar: ai_circtan
ai_circtan
Enter Tangent spec: (Select a line, circle, arc, polyline segment, xline or ray)
Enter second Tangent spec: (Select a line, circle, arc, polyline segment, xline or ray)
Enter third Tangent spec: (Select a line, circle, arc, polyline segment, xline or ray)
0 -
Isn't that an entry for the prompt menu when you enable
"show hidden options" ?
(PromptMenuFlags)Edit :
No, it was just TanTanRad0
