Exportlayout - Error
rmatcfec
edited September 2018 in 2D Drafting
EXPORTLAYOUT
Prior to v18 and win 10 updates I never had a problem with this command, and found it very useful in sending files to other Consultants, now however, I get an INVALID INPUT error, and nothing else... Has anyone else run into this problem, any solutions?
In looking at History, it appears that the error occurs during the file save process.
_EXPORTLAYOUT
Error saving the drawing file C:\Users\...\Desktop\Vista Cay Concept2.dwg
Bricscad V18
Windows 10
Thank you,
Russ
  • I've only used EXPORTLAYOUT with drawings I received from others. I have had the command fail, but it seems to have always been because the author had something unusual in the file. Usually it works fine. If you could post a file that errors we could look, or you could send a bug report (with a file), or both. It is really hard to speculate as to cause without a file.
  • @rmatcfec:
    Try saving to a new folder.
