How to arrange workspace toolbars?
Hi,
I was wondering if anyone knows a good way to arrange the toolbars in the work space?
Any help is greatly appreciated.
Thanks.
Neb
as for my tast UI shold be so simpe as possible
So I normally have to panels openned. Command line and properties dialog.
command line is the most powerful interface as for me.
You should be able to do some drag-and-drop but I've found that if you want to drop a toolbar to the side from the top/bottom (or vice versa), you have to change the toolbar location through the Customize dialog.
Better late than never - Thanks!
Howdy, Stranger!
