Tiny little line on other side of diameter dimension
They appear in the drawing below, a little extender on the other side of the diameter.
Does anyone know how to get rid of them? I tried searching for this but could not find it.
Please help. I checked with my AutoCAD buddy and it's pretty easy to do in AutoCAD. How do you do it with BricsCAD?
0 -
Property Palette > Lines & Arrows > Arrow : NONE ?
0 -
In the dimstyle change the 'Arrow and text fit' setting to 'Text only' and re-apply the style to the dimension.
0 -
You need to adjust your diameters such that it shouldn't overlap with each other. you can ask for other professional services related to cad here cad drafting services
0 -
In AutoCAD, it's Ext Line Offset that does the trick. It seems to do nothing for circle diameters.
Thanks for the help, Roy! I tried "Text only". Although that removes the lines, it also moves the arrows to the outside of the circle.
To get the two arrows, I have to use: "Dim Line Forced", which according to the manual, "Forces the dimension line to be always drawn; forces leaders to be drawn with the DimDiameter and DimRadius commands."
So maybe BricsCAD doesn't support this? Should I look into another CAD package? Or maybe get the drawing tuned in AutoCAD by my buddy at work and then submit it as my assignment....
0 -
Michael, I couldn't find "Property Palette > Lines & Arrows > Arrow : NONE ?"
The stuff I see is on the DIMSTYLE page (here: https://www.bricsys.com/bricscad/help/en_US/Current/BricsCAD/ )
Thanks for the help, though!
0 -
Yes, you can define all in a Style.
I just did a quick test with one radial dimension and looked
what I could change in Object Property Panel when selected.
You can set the same settings for the Style and all Elements
using it.Also I thought your problem were these very little hard to notice
arrow heads. Seems that was wrong and you meant the little
extension at the other end near the numbers.0 -
@robot999:
You should be aware that the username of the person who last saved a dwg is stored in the file. Apart from that, having someone else work on, and finish, your homework assignment is probably never a good idea.Regarding the possible incompatibility with AutoCAD: Please send in a Support Request (attaching your friend's file).
0
