Quad won't expand
Is this something that has just happened, have you maybe had a system update? Does the Quad behave if you use Bricsys Shape?
0 -
Yes, works fine in Shape, in fact using it there convinced me of its value. it used to pop up irritatingly in Bricscad, can't remember when it stopped appearing!
0 -
Does clicking on the top title bar of the Quad open it up further, the only way I can stop the Quad expanding is to give it a really long delay in the settings (you have it set to 1 and those settings work for me), but with the long delay clicking on the Quad expands it immediately.
0 -
I would try to add a bit more Delay to your 3 values with only 1 ms.
And I would try to give them different values.
Maybe they interfere negatively if all things happen at the same time ?0
