Losing reference to drawing after extruding it
- To preserve the source entities change the DELOBJ setting.
 - It is not possible to create an associative link between source entities and extruded solids.
0 -
Hi Roy, I am very thankful for your answer.
Unfortunately that will be a limitation that will prevent me from switching to BricsCAD.
0 -
It would be quite interesting to learn what it is that becomes impossible to achieve without this associative link:
in many cases BricsCAD direct modeling can apply desired modifications directly, without the need to go back and modify the source entities the solid has been created from.0
