Select and print
I want to drag an area and only print that area to pdf, how to do that?
  • When you want to print from Model Space, use the View/Current View option on the PRINT dialog.
    When printing a layout adjust thee size of the viewport to the desired portion of your drawing.
  • Under "Page Setup / Print dialogue" there are the settings for "Plot area" - and there you find "Window".
  • If a selection set exists when you start the Print command, only the selected entities are printed when printing Model Space.
  • Thanks! I got it. Just print, Select Windows then select area to print, scale 1:1 is what I want.
