dadd1967
I'm new to Bricscad and trying to create a simple bent sheet. I am following the video tutorial. When I try to create a flange I get this error "Warning: hard edges were not detected".
Can someone help?
0
Hello dadd,
Likely you call SmBendCreate command while you should SmFlangeBase, SmFlangeEdge or SmFlangeBend. Study the tutorials in
https://www.youtube.com/watch?v=zPTzEKV5IrI&list=PLONdQc9bizseq1btwlPc3j6u4jSK7hSEg . The one you need is "Design sheet metal parts from scratch", while SmBendCreate is for "Rework an imported part".Watch Bricsys channel for updates.
Best regards,
Egor0
