BRXSDK Sample crash
Hi,
I have downloaded and compiled BRXSDK\samples\brxWxSample. After compile I got Sample-brx19.brx
loaded it to BricsCAD with (arxload "Sample-brx19") it works, but if I enter (arxunload "Sample-brx19") BricsCAD will crash. And create dmp file and crash_report.txt.
Is sample working as intended? Should it crash after unload?
P.S.
it will not compile until I add #define _WIN32_WINNT 0x0500
to stdafx.h file.
Hi Donatas
Can you report this via our support portal?
https://www.bricsys.com/en-eu/support/#53 -
I had filled the report. And made a video about it
Howdy, Stranger!
