Shapes don't display
Can somebody please advise where I should start looking at the software configuration if I just don't see any of the shapes as I try to add them to my page. I'm trying to add walls but all I can see are the coordinate pop-ups as I click but no walls are visible.
Thanks!
  • I have seen this happen when the display adapter does not meet the minimum specifications.
  • OK, thanks. I'll check that.
  • Are to cheating entities on a Layer that's switched off? Switch it on and prob umpteen attempts will all become visible!
  • rkmcswain has the answer: my display adaptor is not powerful enough
    I can use my daughter's laptop.
    Thanks for your help!
