batch printing multiple formats in model space
Hi, I'm a survey draftsman and we mainly work in modelspace for our drafting.
In Autocad we could set-up named sheets in plot and create a dsd file through publish.
Publish in Bricscad doesn't allow this feature..
Is there somehow people have got around this, ie lisp routine, etc?
Thanks
Yes. Is it possible.
Maybe this will help you:
Revers - Automatic batch printing a multiple format (rectangles, frames) of model space and layouts -
The BricsCAD Publish dialog has a Save button to save the current sheet list to a .dsd file.
Is this what you are looking for or do you mean something else? -
@maratovich thanks but that program has a nice Trojan associated with it..
@Hans De Backer yeah that is similar to Autocad but it seems in Bricscad that you are only allowed to save sheets if they are in different drawings.
@JoshLPL said:
@maratovich thanks but that program has a nice Trojan associated with it..No viruses !!!
Checked by all antivirus.
Update your antivirus.
What is your antivirus? -
@JoshLPL said:
@Hans De Backer yeah that is similar to Autocad but it seems in Bricscad that you are only allowed to save sheets if they are in different drawings.I can save a sheet list from within a single drawing using the publish command, it makes no difference whether all sheets or only some sheets of that one drawing are published. No other drawings were open, just that one drawing to make sure it works with a single drawing.
This is in V19, are you perhaps using an older version of Bricscad?
Howdy, Stranger!
