It looks like you're new here. If you want to get involved, click one of these buttons!
Hi,
is it normal behavior (V19), when using the Layer Toolbar, Layer-Pulldown Menu to turn on, off, freeze or lock other layers, that i can not change the current layer?
I can not select any other layer to define it as the current layer.
I have to exit the Pulldown Menu and select a 2nd time the current layer in the Pulldown Menu?
Are these X-REF layers?
I agree, that is a bug.
I also found that annoying, I have opened a support request.
good news!
Thank you for feedback, this has been fixed in the current code. the fix will be available in the upcoming release .
Thanks @fs_at12 !
