Placing Viewports in Paperpace
Hi,
How to place defined view in paperspace as a viewport. This can placed in AutoCAD but how to place in BricsCAD as i am unable to place it.
Regards
Manohar Boddu
If you first place a viewport in a layout you can use the "-view" command to "restore" a named view in that viewport, or are you trying to do something else?
Hello Steven,
I have created a View of a sample 3D model and I want to insert that view as Viewport in Paperspace. Attached model for your reference.
Regards
Manohar Boddu -
How did you create a view I don't see a named view? just your model.
I think you are looking for the PlaceView command: "Places a model view selected from a source drawing into a paper space layout of the current drawing." See https://help.bricsys.com/hc/en-us/articles/360006770033-PlaceView.
Model views (saved views) can be inserted in a layout of an open drawing by drag-and-drop from the Content Browser panel. See https://help.bricsys.com/hc/en-us/articles/360006659673-ContentBrowserOpen.
Howdy, Stranger!
