Ribbon is on palette with Properties, want it back in default location
I was experimenting and wound up with the Ribbon on the Properties Palette. I want it back like the default, which is like AutoCAD has it displayed. Can someone help out? Thanks, GP
  • I finally tried grabbing the Ribbon tab on the palette and dragging it up to the top and it docked there the way I was wanting. Answering my own question in case someone else has the same problem.
