Changing the UCS (Workplane)
If I want to create a Cylinder in the X/Z plane as opposed to the X/Y - how would you do that?
look at
To define a User Coordinate System
https://help.bricsys.com/hc/en-us/articles/360006808353-User-Coordinate-Systems0 -
@fs_at12 said:
Blehhhh... not having to work with the UCS was a HUGE reason we all dumped AutoCAD for 3D and went to SketchUp back in the day. This is a major area for "Ease of Use" which must be addressed.
0 -
In many cases the Dynamic UCS (DUCS) can/will take care of the orientation of the UCS. In a typical BIM workflow the UCS command will be rarely used.
0 -
I was just working with Shape and wanted to create some horizontal beams. Thanks for the tip.
0 -
The DUCS is switched on in Shape.
Start the _Cylinder command, hover over a face... etc.0 -
With DUCS, you can create a dummy solid to use for alignment, create your object, then delete the dummy solid.
You could also MANIPULATE the object into position after creation.
Regards,
Jason Bourhill
CAD ConceptsCome to the Australasia BricsCAD Conference
0
