How to list all entitiies on a layout page
A layout object has a block property. That property is the block definition that contains all the paper space objects belonging to that layout. So you can just iterate over all the items in the block definition.
To see a list of all entities in the current layout, do the following:
1. Press Ctrl+A to select all entities
2. In the Properties panel, click the Quick Select button . The list button shows the number of entities.
3. Click the list button to see the numbers per entity type
Howdy, Stranger!
