Allowing triangulation 3D solid
Hi,
Just wondering if Bricscad has this option or something similar?
I used it quite a bit in Autocad when editing vertices on solids.
Thanks in advance for any info. Josh
  • Looks like Bricscad doesn't do that.
    No single Vertex editing at all.
    If I try to force that by Mooving Solid's Edges in 2 Directions,
    it will keep the effected Face planar.
  • I also miss this function in BC. :-(
  • I've lodge a support request. They are looking into it now and I will let you know what happens.
