Bricscad Slow When Building Walls
I find that Bricscad is slow when maneuvering about the model while building walls. What settings are others using to speed up maneuvering while building walls.
It is also sluggish when trying to snap to a object. I am using the latest version of Bricscad 19
I think that I found the problem.
Bricscad does not like driving a 4k monitor from a laptop.
Reverting to 1920 x 1080 resolution speeds things up. Although the display is not the best. -
Fix confirmed with the purchase of a new 1920 x 1080 monitor. 4k monitors need a decent graphics card with plenty of memory.
Howdy, Stranger!
