Teigha Table Row and Column Count Setter failure [.NET]
Working with the CsBrxMgd Project .. cleaning up Errors and warnings ..
There is a failure with the Teigha Table Row and Column Count Setter
The warning and error as reported by my compiler ( VS 2019, NET 4.7.1 )
The report is as shown in the piccy, so I needn't regurgitate it.
The Reflector view of // Module TD_Mgd.dll Version: 4e794c44-d485-4d80-abb5-de42c903360d
shows that no setter is available.
I can and will use the depricated Table.NumRows property BUT the Table.Rows.Count setter needs fixing.
I always use Table.SetSize when creating a table
0 -
Thanks Daniel
... I just noticed that in Reflector and left a note to do some research
< virtual black jelly-beans transmitted>Stay Well.
Added:
Works a treat !
Thanks Dan0 -
Also, an advisory note for future users
Compiling to AnyCPU on an x64 machine causes the following COM warnings.
The warnings are not shown if the Solution Platform is set to x64Regards,
0 -
Oooops ... Needs Looking at I think ..
0
