TXT2MTXT not working
Hi, I've downloaded ExpressTools from the Bricsys website and installed it per the included instructions. I'm trying to use the txt2mtxt command, but I keep getting the following error:
TXT2MTXT
Entities in set: 2
----- LISP : Call Stack -----
; [0]...C:TXT2MTXT <<--
; ----- Error around expression -----
'ENAME
; in file : C:\Program Files\Bricsys\BricsCAD V18 en_US\Express\leaderex.des
; error : bad argument type ; expected at [*]'
Can anyone explain this to me or suggest a way to fix it?
