Error after install Bricscad V19
Hi,
I got problem when I successful installed Bricscad V19. But after I run Bricscad, got notification "The program can't start because api-ms-win missing from your computer"
I attached the problem notification.
thanks
0
Do you have some Anti Virus Software running ?
It could block or delete Bricscad components while installing.
It may be worth to shut it down while installing and check when
running Bricscad. Maybe you need to exclude Bricscad Folders
from Antivirus checking too.0 -
thx for the respon, I'll be trying
0 -
In the worst case that DLL is really missing for some reasons.
That would mean to check and repair Windows.0
