How to launch BrisCAD from Excel VBA
1. How to launch BricsCAD from excel VBA(2003)
2. Do I need to append "BricsCAD APP 11.0 Type Library", "BricsCAD DB 11.0 Type Library" or others from EXCEL VBA ?
3. How can I draw polylin,text,dimension fom EXCEL VBA to BricsCAD?
4. Any other examples in your Web site?
5. Any eBook about BricsCAD VBA manuals ?
Thanks,
Joe
0
Here is a example of AutoCAD.How to modify the code can run in BricsCAD?
Public Graphics As AcadApplication Public Sub OpnAcad() Dim strDrawing As String On Error Resume Next Set Graphics = GetObject(, "AutoCAD.Application") If Err.Description > vbNullString Then Err.Clear Set Graphics = CreateObject("AutoCAD.Application") End If ' ACAD.Visible = True strDrawing = "c:\0\Test.dwg" Graphics.Documents.Open (strDrawing) On Error GoTo 0End Sub0 -
Hi Joe,
you need to update the application reference
[code]Public CADapp As AcadApplication
Public Sub OpenBcad()
Set CADapp = GetObject(, "BricscadApp.AcadApplication")
Err.Clear
Set CADapp = CreateObject("BricscadApp.AcadApplication")
End If
strDrawing = "D:\Temp\TestDrawing.dwg"
CADapp.Documents.Open (strDrawing)
CADapp.Visible = True
On Error GoTo 0
End Sub[/code]
Note you have to include BricsCAD in your references. See screen grab attached
Regards,Jason Bourhill
CAD Concepts
Excel-References.png0 -
Joe,
Should of also said to look at the Developers Reference
There are a number of examples under the COM section
CAD Concepts0 -
How can I draw "line" from Excel VBA to BrcisCAD?
The example in attached file
0 -
The only issue I ran into, when I did the same, was that both the BricsCAD and Excel programs need to be set to run as administrator.
-Joe
0 -
https://www.bricsys.com/bricscad/help/en_US/V17/DevRef/source/VBA_VBA.htm read this post yah it helped me thank you nice source
Regards0
