RMB Enter
I thought this was a default where a quick right mouse click made the enter command or brought up the last command. I seem to have lost this while doing some customizing and now I get the snap menu only. Is there a setting for bringing this back?
thanks..
Search the the OPTIONS menu for SHORTCUTMENU.
In (Quad) Settings there is a QUADCOMMANDLAUNCH...
to en-/disable last Command by RMB+Quad
(I think that needs either a loooong RMB+RMB release or
a second LMB click)When that is off you will get instand last Command with a
standard RMB click (but no more Quad) -
Thanks, I'll try these options.
Howdy, Stranger!
