AcCoreConsole in Bricscad
Hi
Is there any similar tool to Autocad AcCoreConsole in Bricscad ? Its a application to run scripts without opening files. I want to write a script that use command 'wblock' on several dwg files in the folder without opening this files.
0
It's not exactly the same thing, but you can run BricsCAD invisibly in the background by specifying the /automation switch at the command line.
0 -
@Owen Wengerd said:
It's not exactly the same thing, but you can run BricsCAD invisibly in the background by specifying the /automation switch at the command line.Its very interesting but I need more detail. Could you type some example or link to bricscad help or to good book? I need only help with run in invisible mode
0
