What happened to Boundaries ?
I never tried that in previous Bricscad Versions but I am not
able to get any Boundary over more than one 2D Object.
(Something like a Boolean Union, as the Tool Icon promises)
I can only get the "Fill Bucket" or Boolean Intersection Mode
of any 2D Geometries.
TAB or CTRL doesn't switch any Boundaries,
The Draw/Boundary Tool says 5 Selected, 0 created,
and if I trie harder - Bricscad v19 Win crashes.
I am I doing it wrong or is there something broken ?
Booleans are for regions. First convert polylines to regions and then use booleans.
0 -
Thanks CADMebel,
Although I recently learned that Regions are ACIS (Solids?),
Boolean Operations only work for real Volume Solids.But I mentioned Booleans only to describe that "Boundary Selection Mode"
or (2D?) Boundary Tool for me will only work for interior Boundaries
inside Borders of any 2D Edges.
What ever I try, I can't get them to select the whole outer Area of
e.g. 2 Overlapping Rectangles.
Basically what their Icon shows and promises - and what I think to have
seen in Videos in the past.If you hover an edge, coming from the inside it will choose the next
inner Border - if you hover over the edge coming from outside,
it would choose the Boundary around ALL Objects.
That is what I remeber.0 -
Try this lisp routine by Lee Mac - http://www.lee-mac.com/outlineobjects.html
0 -
Thanks for the Lisp CADMebel.
I may have dreamed or wishful thinking.
Also tried in v18 on Mac.
Looks like that "outer Boundary" Feature never existed.I was thinking about that Video, but inner Boundaries only ....
0
https://www.youtube.com/watch?v=m5M9QQiJces
