Move/Copy/Rotate
I am a recovering AutoCAD user in the civil engineering area. One tool i used CONSTANTLY in AutoCAD was the "Move/Copy/Rotate" tool in the ET: Standard toolbar.
Is there a tool with this power in BricsCAD? Using Pro 19.2.03 rev 60650
Thanks!
  • I don't use MOCORO but I think it is included in the Express Tools for Bricscad. Available in the Bricscad app store or at www.cadweisel.de.
  • Hi I have used this little LISP for ages. ( noticed I first saved it in 1990 )
    (defun C:MOVER ( / SS1 P1 IN INP YN ELAST)
    (prompt "\nSelect Entities ")
    (setq SS1 nil SS1 (ssget)
    P1 (getpoint "\nReference Point:")
    IN 1 YN 1)
    (while YN
    (while (/= IN 2)
    (prompt "\nCopy/Move/Rotate/Scale/mrror/reft/Quit ")
    (setq INP (grread)
    IN (car INP))
    (if (= IN 2)
    (setq YN (strcase (chr (cadr INP))))))
    (cond ((= YN "C")
    (setq ELAST (entlast))
    (command "COPY" SS1 "" P1 pause)
    (setq P1 (getvar "LASTPOINT")
    SS1 nil SS1 (ssadd))
    (while (entnext ELAST)
    (ssadd (entnext ELAST) SS1)
    (setq ELAST (entnext ELAST))))
    ((= YN "M")
    (command "MOVE" SS1 "" P1 pause)
    (setq P1 (getvar "LASTPOINT")))
    ((= YN "R")
    (command "ROTATE" SS1 "" P1 pause))
    ((= YN "P")
    (setq P1 (getpoint "\nNew Reference Point")))
    ((= YN "S")
    (command "SCALE" SS1 "" P1 pause))
    ((= YN "I")
    (command "MIRROR" SS1 "" pause pause pause)
    (setq P1 (getpoint "\nSet New Reference Point ")
    ((= YN "Q")
    (setq YN nil SS1 nil)
    (gc)))
    (setq IN 1))
    (princ))
  • 1990 must be something wrong there I was still on PAFEC DOGS if anyone heard of it.
  • 1990 must have been the year for Moving, Copying and Rotating!
    The only problem with this routine is if you use the copy/rotate, if you cancel or undo it will leave a copy sitting on top of the original entities, so make sure you undo beyond the initial calling of the command.
    If anybody has a better version of this I would be interested to see it.
    It was certainly the year for adding comments
    Yes ! Built in and ready to go.
  • Jason Bourhill
    edited June 2019
    GRIPS work too. :smile:
    Regards,
    Jason Bourhill
    CAD Concepts
  • @Louis and Kerry,
    Thanks for opening my eyes to the Manipulator in 2D, I had only been using it in 3D and after a quick play in 2D after seeing your comments, I have realised how useful it can be. ;)
Howdy, Stranger!
It looks like you're new here. Click one of the buttons on the top bar to get involved!
