Teigha.DatabaseServices.FieldEngine
Has anyone done any work with this ??
FieldEngine Class
Inheritance Hierarchy
System.Object
  System.MarshalByRefObject
    Teigha.Runtime.DisposableWrapper
      Teigha.Runtime.RXObject
Namespace:  Teigha.DatabaseServices
Assembly:  TD_Mgd (in TD_Mgd.dll) Version: 19.5.0.0
Regards,
  • Hello Kerry,
    I’ve worked with AcFdFieldEngine a bit.. just enough to be able to hack up a .NET sample.
    Load the module and paste this in the mtext editor %<\FC_STARDATE>%
    StarDate 73501.26, seems a bit off though
  • Thanks Daniel,
    I'll have a play when the crocodiles stop nipping at my heels.
  • @Kerry Brown said:
    Thanks Daniel,
    IKR! We found a huge croc (by our standards) in the gutter… the week before, a cobra fighting a python, meanwhile, mynah birds continue to sneak in and eat my bananas. It’s a jungle out there.
    SQliteLsp has a field evaluator that excepts SQL statements, that may serve as a better sample, while its C++.. well.. just replace the -> with . and it should be readable
    Cheers :)
