How To Suppress "Last Saved Version Y/N" Message
A co-worker using BricsCAD Classic v19 is experiencing the subject message appearing and wishes to disable it.
Where is this setting located?
Reason: The application locks until a Yes or No is chosen. A wrong answer to that prompt caused him to lose work.
Thanks,
Clint
  • The complete message is probably:
    The drawing "xyz.dwg" is already open.
    Do you want to revert to the last saved version?
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
