GROUP & UNGROUP
- -GROUP and (Command)
Provide an easy way to combine drawing objects, in AutoCAD by right clicking with individual block I can edit easily, that’s best and short way. in Brisa this option must do by command and little time consuming,
UNGROUP(Command)
AutoCAD- entities can be ungrouped easily without breaking entities,
BricsCAD- explode command only available it breaks all entities (after explode it will convert from polygon to line, this is not good)
The _Explode option of the _-Group command is not equivalent to the _Explode command.
This may be of interest:
http://www.b-k-g.nl/bkg_group.html0 -
Hi Terry, I know you don't provide technical support for your freeware but for your information, I just downloaded Group Manager and was unable to make it work in V19.
The following is what it said on the command line after I located the 19b.dll using netload.
"Error Message: Could not load file or assembly 'file:///C:\Program Files (x86)\Dotsoft\GroupManager\GroupManager19b.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)"
I had to create the path you mention in the html file as there was no installation only a zip file to download.
Many Thanks
0 -
Things to consider:
- If you have problems NETLOADing, you may need to unblock the DLLs using Windows Explorer.
- Netloading from network drives may fail, consider using a local drive/path (like C:\CADSTUFF).
- After the first manual load, the add-on will automatically load for subsequent sessions.
- All CAD sessions must be closed before DLLs can be deleted or updated.
- You can safely delete any GroupManager##.dll you are not using.
0 -
Thanks Terry, I forgot about unlocking .dll's, it works perfectly now, thanks for the routine and the help.
0 -
Discovered the Delete button wasn't working, also added select all, clear all buttons. Download ZIP file revised.
0 -
GroupManager updated with minor revisions, support for v20.
0
