bricscad is slow on our system
Hello All
We are having an issue with our system, we have good system with 48GB Ram an 8 Gen 6 core CPU and an Nvidia GTX 1080. the system takes lots of time to do anything with bricscad, printing takes long time, is their a setting to the graphic card that could speed things up.
  • It is really hard to say with the data you provided. A fast computer is only part of the story.
    Are all of the Bricscad support files local to the computer or are they on a server? How fast is the network? What types of drawings are you working with? Have you purged your drawing and erased anything that's not a part of your drawing?
    Some operations like changing fonts for a text style take a lot longer over the network than they do with local font files. A 100MHz network may seem slow. One of my clients starts new drawings by importing an old drawing into model space. This gives them their standard layer configuration, but it makes the drawings much larger than they need to be. All the extra entities in the database also slow down any operation that iterates across the whole database.
  • actually, this seems to apply only to the laptop, the other, workstations are fast, the thing is that the workstations have older quadro graphic cards, while the laptop got the Nvidia GTX 1080. it seems weird that the new computer is much slower than the older one.
  • Was there any update on this? Same problem here on my laptop. Older workstations with older less sophisticated GPU's are better performing than my new state of the art laptop…
  • Maybe Bricscad is not using the GTX 1080 but only an onboard graphic on the CPU ?
    On the PC I had to manually add my CAD and 3D software to explicitly use the dedicated GPU in Nvidia driver software and Windows energy settings.
  • Agree with Zoomer on my laptop have CAD set to use Nvidia. trying to remember how to do it.
  • Its_Alive
    edited December 2025
    I’m still using a GTX 1060, while it does not show as an optimized application in my game ready driver, I can still see it using the GPU when I monitor with windows performance monitor and play around 3D objects.
    Generally, BricsCAD seems pretty fast for me, though I have found one area where it seems to stall, and that’s with a large number of large polylines as in civil contour lines.
    I’ve attached a drawing that contains a proxy object that’s super slow on BricsCAD and zippy on other CADs. Its an extreme example, most other drawings have no issues.
    I’ve been using this as a performance test as it’s only a single entity, so what ever the hit is, it’s not from the number of database objects, it’s the number of primitives
    Edit: BTW, the source for the entity is here, https://github.com/CEXT-Dan/ArxTin
  • zoomer
    For me here your demo file looks like working in real time.
    v26 on a MBP M4 Max.
    Clamshell Mode, external 4k Display set 3008 x 1692 @ 60Hz
    (Internally it even calculates with 6016 x 3384 to display final uneven scaling)
    Even in the original 2D Wireframe Display Mode, which AFAIK has no GPU acceleration (?)
    No difference in 3D Dsiplay Modes.
  • I have “All the CADs” for windows installed on old paint. Generally, they’re in the same ballpark with regards to performance, except this entity is like dragging around Thor’s hammer with any TransformBy. BricsCAD definitely has different behavior on this one.
    I don't think this uses GPU acceleration.
  • BricsCAD uses the GPU for small, low entity count dwgs adequately in modelspace, but paperspace with shaded viewports, performance is atrocious.
    In dwgs with loads of entities, 20,000+ when zoomed in close it uses the GPU with good frame rate but zoom out with the full model in the viewport and GPU utilisation maxes out max about 30% which results in frame rates less than 10FPS, IOW poor performance (blocks being the majority of entities).
    Interestingly, meshes perform very badly in BricsCAD, even small ones, in comparison same dwg in AutoCAD 2026+ super fluid, silky smooth high frame rate, AutoCAD’s graphics engine has been significantly improved over the past few years, light years better than BricsCAD, and switching Paperspace Tabs happens in the blink of an eye, talking 2-3 shade with edges VPs with transparency, no slow down huge contrast in BricsCAD…(makes me wanna inject myself with acid).
