Section to Block Problem
I have inserted a Section Plane through my 3D model, but when I'm looking to export the Section as a block I then get a ''inconsistent face-body relationships'' error?
Does anyone maybe know why I'm getting this error, thanks.
Inconsistent face-body relationships can occur if the section plane is the same as the plane of a face on the solid. Can also occur if the solid somehow has 2 parallel faces with zero space between, or very thin wedges left after boolean operations, or some other modelling error. Try doing solids checks on the model entities.
0 -
Related issue. Please help.
I created a TIN surface from points.
And need the volume of a depression. (Water Storage)
I tried to use TINvolume and TINextract to make a solid out of the depression.
But the resulting solids will not give me a volume in the properties listing when I select the resulting solid.
I also tried solid/solid intersect and surface /solid slice to create a solid I could read the volume on.
These operations resulted in the "inconsistent face-body relation ship" error.Any ideas what the issues is.
Sounds like I generated a bad TIN surface if that is possible from importing points0 -
New info: inconsistent face-body relation ship / Tin
I reviewed my point data and found many duplicate points and deleted them.
When I ran TINVolume w/ elevation and default bounding area it worked.
But the resulting solid appeared so far out of my working view I almost missed it.
When I selected it the solid that was created, properties showed cu-yds, cut & fill as desired.
But the values seem very large.
Checking into that now.Sometimes it seems values show are in inches or cu-in but the units read feet, sq-ft, or cu-yds.
Could I have set something wrong in settings?Thoughts?
0 -
TINVolume / Unit Issues;
The solid TINVolume created came in at a 0 elevation. I was working at 5200' Elevation. Which explain why it appeared outside my view.
Not sure if I set that or if it is a default.Length and cords of a simple line displayed in properties window are in inches. But Length unit reads ft.
Coords are unitless in the display. Obviously I have screwed up something in settings.I would like cords & lengths in feet (decimal), areas in sq-ft & acres (decimal) and volumes in cu-ft, cu- yds, & Ac-ft (decimal)
Thought I finally had it set right, guess not. And I hate putting a ' after my inputs.Assuming volumes are most likely in cu-in I can manually convert them.
Suggestions?
0
