How to turn on the HKA (hotkey assistant) back on?
When using the connection-setting from the quad, I accidentally closed the HKA (hotkey assistant). Is there a way to turn it back on? The roll-over tooltip at another HKA suggests that I click the HKA-button on the statusbar. But there is no button there? Am I missing something here?
Thanx!
The little down arrow extreme bottom right of the screen - activate HKA tab there.
Could you point that out please? I don't see it.
Version 19.2.13 (x64) revision 65539
OK, found it in Bricscad.
Looks like not available in Shape. -
Tried to uninstall the complete app and then reinstall it, but the settings don't seem to be restored...so unfortunately no HKA in shape I don't know if software development is watching these fora?
If you are using Windows:
Exit Shape, go to this key in the registry:HKEY_CURRENT_USER\Software\Bricsys\BricsCAD Shape\V19x64\en_US\Profiles\Shape\HotkeyAssistantContext
And delete all REG_DWORD values. -
YEAH!! That did the trick! Many thanx!!!
Howdy, Stranger!
