Windows Door - in insertion switch between localisation and dimension of the door doesnt't work
Hello,
I'm quite new in BricsCad, (previously user of SLDW).
Configuration : Bricscad V19 Ultimate. Windows 8.1.
I'm trying to insert a door in the wall of a room in my BIM composition (BIM profile)
OK, I take the block and drag into the wall. That's works. I precise the localisation (but strange and complex not from the wall of the room but from the envelop of the building).
I want to fill the dimensions of the door.
So I click ctrl.
Nothing the fields to fill to dimension of the door don't appear.
Did I have missing something ? (DYN is on)
How can I fill the dimesions of the door ? (please process step by step).
Pressing the Ctrl key in the insertion process should toggle between placement distances and insert dimensions. Also the AltGr key can be used. If this doesn't work, please file a support request and attach one of your models and your user profile (.arg): type PROFILEMANAGER at the command prompt, then select the current profile and click the Export button.
0 -
Thanks, Ctrl doesn't work but AltGr works.
0
