Proper method to contact support
Hello, I am new to BricsCAD as of a few days ago. This is my first post. I'm using the Pro version of 2D 2019 . I'm having issues requesting support. I have found two ways but only one will get me into the priority Que. Will someone please tell me the proper method? Any suggestions will be greatly appreciated.
Thanks,
Russell
For me,
https://auth.bricsys.com/auth/realms/bricsys-account/protocol/openid-connect/auth?kc_locale=en-GB&response_type=code&client_id=bricsyscom&redirect_uri=https://www.bricsys.com/login&state=1255949d-9297-468e-83da-d86136d953cb&login=true&scope=openid
May be different alphabet soup for you.0 -
Thanks for your reply Tom but that gave me a server error.
RussellThanks Per Gogstad that works for me.
RussellNow I need to know the proper way to thank those who respond to my post. Also how to set up to be notified when someone does respond. I cannot find the rules for this forum.
0 -
There is the star at the to right.
It will give email notifications.(Unfortunately for all, not the first post)
I found even a way to get notifications for whole
sub forums. Maybe in my profile settings ?0 -
In your Account Options (cogwheel to the right of your account name) you can edit your profile and set the Notification Preferences.
0 -
Above the 1st post, in the row where the thread title is,
on the right side there is a shy symbol of an outlined star.If you click on it to activate,
it will get a yellow fill color and you will get notifications
whenever someone adds a post.
Depending on your notification preferences in your account
settings.0 -
Never mind I found it. I see that I have to bookmark the one I want to follow?
0 -
Ah, yes, it is called Bookmark.
0 -
@Slim said:
Where is account options. I log in and click on the little man and in the flyout I click on my name and I am carried to my profile.
Never mind. I found it.
Thanks0
