Line perp to line
Is there a snap-based procedure to pick a point on a line and draw another line away, perp to the first line?
Yes you can. See attached animated gif: I have Polar and Strack ON. Esnaps Midpoint and Perpendicular are ON.
0 -
The perpendicular Snap ?
(I have that always on)But I think you mean a new Line that doesn't even touch the base line ?
So anywhere in space but just perpendicular to the base line ?If so I would go from the initial point, reaching and P-snap the base line
and change their length afterwards (graphically or by properties).But since V20, DUCS works for 2 Elements too.
So you can align DUCs and lock it with SHIFT first,
then snap your first point and draw the line in POLAR along the
perpendicular axis.0 -
Works nicely at least from V18 .
to draw a line pick a point , choose your snap, touch the line you want the snap to apply to, move the cursor until it gets a snapline.
works for both parallell and perp.0 -
Thanks boys - yes since asking the question the Perp-based was has been magically working for me too - have yet to explore the DUCS based solution
0
