Draw Line along surface
Hi,
I need to draw a line on a road surface that consists of 3D-Faces (yellow in the picture), so that the z-values follow the shape/profile of the road surface. The position (ie x and y values) of the line is given by an existing line with a z-value of 0 (blue line in picture). What is the easiest way to do this?
The wanted result can be seen with the red line in the background.
