Switching ANNOALLVISIBLE on/off
I'd add a toolbar button to toggle this. This has the advantage of showing status if you choose to do so.
I have a function that toggles a user variable to change whether symbols are inserted aligned to the selected linework or not. The Diesel function is: $(if,$(=,$(getvar,useri5),1),!.,) and the Command is: ^P'useri5 ^P$M=$(xor,$(getvar,useri5),0x0001)
You could probably do something similar.
You could also do this in lisp with something similar to
(defun c:toggle-tilemode ()
(setvar "cmdecho" 0)
(setvar "tilemode" (boole 6 (getvar "tilemode") 1))
)0 -
Just found the toolbar button and added this to the Diesel call.
I never realized that this variable in MS and PS are stored seperately from each other!
This button shows in turned on/off mode!0
