Point style selection?
The command ddptype in AutoCAD brings up a simple table whereby you select a point style. Quick and easy. Typing this command in Bricscad brings up a confusing ledger of entries in Settings which I don't understand at all. I've read the help file - in it is a very nice table similar to the aforementioned dialog box in AutoCAD but evidently this nice table is not available at the command line. Actually, the only point style I ever need is "X" so if it could be explained how to make that the default, I would be good to go.
Thank you,
  • 3 rows in what you call the 'ledger' are dedicated to the PDMODE setting. Please click in all 3 fields...
  • Thank you. I was able to get the setting I need by entering a value of 3 in the "mask: 0x000F" line. However, a table like is shown in the Help entry (or in Autocad) would make the process a lot more user friendly.
    I agree. We could really do with an interactive point dialogue.
    What I sometimes do nowadays when adding important points is to use x shaped blocks, sometimes annotative if needed.
    I also used to use points a lot for dividing and measuring along lines etc. but now tend to use the array along path instead. Probably because of the inconvenience of points.
  • When you change the PDMODE value in the _Settings dialog a preview of the result is displayed (below the tree/grid view). IMO this is interactive enough. But maybe the GUI would be clearer if fields that are in fact dropdown lists always show the arrow symbol.
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
